AKAI receiver, cassettedeck, platenspeler (Aangeboden)
door Gino @, Vogelenzang, 01-07-2013, 18:05 (4677 dagen geleden) @ Gino
Gewijzigd door Gino, 01-07-2013, 18:12
In nette staat verkerende Akai Receiver.
Type AA-R20
Bouwjaar 1979/1980
Alle lampjes/VU meters werken.
Reageert zonder antenne al op zenders.
45 euro
Specifications
Tuning range: FM, MW
Power output: 26 watts per channel into 8 Ohm (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.05%
Damping factor: 40
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 75dB (MM), 90dB (line)
Channel separation: 50dB (MM), 50dB (line)
Output: 150mV (line)
Speaker load impedance: 4 Ohm to 16 Ohm
Dimensions: 440 x 142 x 310mm
Weight: 8.5kg
Accessories: FM di-pole antenna
