Aansluiten TVCCD-314COL camera (Toestel of techniek)
door Maurice ⌂ @, Dordrecht, 14-07-2013, 19:10 (4675 dagen geleden) @ hdegreeuw
Doe eens een google zoek optie
"Passive Video Baluns"
Passive = zonder active componenten - dus geen Ic's versterkers of wat dan ook.
Enkel weerstanden en wat condensatoren.
Verder zenden en ontvangen over Ethernet kabel (Cat5).
Voor de werking heb je aan beide uiteinden dus een kastje nodig.
Eyeonfly Passive Video Baluns
Passive BALUN – VTA6001
Overview
The Eyonfly Active Balun transmits and receives video low-cost unshielded twisted pair(UTP) cable.
It is easy to connect, CCTV Security and Sureillance equipment by using standard structured cabling techniques. The optional2 crews provide the simplest means of sending voltage power or RS-485 PTZ Control signal.
Features
1. Transmission distance up to 2450 feet(750m) via Cat5 UTP
2. Immunity to noise and interference
3. Passive device
4. Compact design
5. 2 Optional screws for PTZ control or power transmission
Specifications
Environment
- Close-Circuit TV(CCTV) equipment for security and surveillance.
Devices
- CCTV Cameras, Monitors, switchers, sequences, multiplexers, digital video recorders (DVR) and other CCTV
