Philips GF446 (Gezocht)
door Maurice ⌂ @, Dordrecht, 04-12-2013, 23:19 (4396 dagen geleden) @ vandermeer
Gewijzigd door Maurice, 04-12-2013, 23:32
I cannot find this fuse
This fuse is stuck into the coil of the transformer.
You can find it bij looking closely at the terminals.
Coils are copper, the fuse is blank wired.
Then measuring those 2 points of that fuse,if broken attemt first with an outside fuse the transformer.
Maybe the fuse is just blown deu to the very empty capacitor, that after a long time without a voltage should be reformed first.
Fuse can be taken out sometimes.
If it is a solder one, don't put new solder on it but with a clean tip of your iron just resolder with the tin on the fuse.
The tin used with this kind of thermo-fuses is of special aloy.
Otherwise just put a new glass fuse outsite with the mains for safety reasons.
And repoint or short the old fuse.
Maurice
Picturs of the transformer- somewhere on the net found
transformer is 311232830211
