Schaub-Lorenz music center 6000 (Toestel of techniek)
door v1ncent ⌂ @, Bredevoort, 10-09-2014, 22:42 (4329 dagen geleden) @ robot797
Robot,
2 minuten goochelen bracht me dit op: http://www.alibaba.com/product-detail/-NEW-LDR05-RPY30-FW300_597913813.html, ongetwijfeld moet er wel meer info te vinden zijn. Kwam dit ook nog even snel tegen: Laub Schorenz 5001 met de volgende tekst:
The tape deck was refusing to work so I removed, cleaned and tested all the relays on the control board PCB. Now it started to show sign of life. It would play to the end of the track and then rewind but it would not advance to the next track and play. This is a common problem caused by a faulty LDR that detects the start of the tape, through the transparent leader. I couldn’t find the original Valvo LDR05’s but I could get some LDR03’s, which have the same electrical characteristics. The second LDR, used for the recording level, was also found to be faulty and was replaced at the same time.
Succes!
TB-303 <3
