Philips 2A of 2B ktv (Gezocht)
door Maurice ⌂ @, Dordrecht, 12-12-2014, 21:46 (4158 dagen geleden) @ henkk56
Beste om te zoeken is de typelijsten er bij te halen.
Dat zoekt wat sneller.Zie onder aan bericht.
Mijn Aristona 68KE4905/03R (2B 1986) heeft tot nov 2009 toch
menig uurtjes dagelijks staan spelen.
Da's 23 jaar waarvan de laatste 8 jaar in mijn bezit.
Werkend weggedaan in nov2009.
Reparatie tips 2A en 2B chassis:
Voor de gehele lijst - mail maar even.
Philips 2B + 140 V not present Check soldering points of SOPS-transformer (T5663) and line
transformer (T5620)
Philips 2B + 140 V not present Replace TS7687 by 2SC3973B (4822 130 60851),
change R3671 into 22 Ohm/5watt (4822 113 41152) and
replace TS7685 BC547 (4822 130 44257) and
replace TS7686 BC369 (5322 130 44593) and
replace D6690 BZV85/C5V1 (4822 130
Philips 2B Blanked pic for first 5 mins from sw on check/replace 6x33k res on crt base; add 1N4148 in series with D6492
Philips 2B Causing interference to FM radio reception. Mod.
Philips 2B Checking the power supply Checking the power supply
1. Remove connector M17
2. Connect a lamp 220V/75W across C2701
3. Switch on set
4. Lamp lights, +140 V present
This means power supply is OK
Philips 2B Dead - blown chopper transistor. T7685/6 , D6686 , D6672 , D6607/71 , D6690 , R3687 , R3670 , C2690.
Philips 2B Frontend FE618Q/256 in repair procedure
Philips 2B NO PICTURE FROM COLD PICTURE APPEARS SLOWLY FROM B C2571 100uF 25v IN FIELD CCT
Philips 2B No picture, sound OK (narrow line when increasing G2 voltage) IC 7550 (TDA8370) is defective.
Possibly resistor 3535 (10 ohm) is disconnected.
247062 2A 1986
20CE2060 2A 1985
20CE2240 2A 1986
214032EK 2A 1986
21CE2340 2A 1986
21CE2640 2A 1986
226002EK 2A 1986
226102EK 2A 1986
226122EK 2A 1986
226152EK 2A 1986
22AV1114 2A 1986
22AV1130 2A 1986
22CE2061 2A 1986
22CE2064 2A 1986
22CE2065 2A 1986
22CE2261 2A 1986
22CE2267 2A 1986
22CE2561 2A 1986
22CE2565 2A 1986
22CE2567 2A 1986
247032EK 2A 1986
24CE2370 2A 1986
24CE2670 2A 1986
268002EK 2A 1986
268022EK 2A 1986
268052EK 2A 1986
268102EK 2A 1986
268122EK 2A 1986
268152EK 2A 1986
26CE2080 2A 1985
26CE2081 2A 1986
26CE2281 2A 1986
26CE2282 2A 1986
26CE2581 2A 1986
279032EK 2A 1986
279062EK 2A 1986
27CE2390 2A 1986
27CE2391 2A 1986
27CE2690 2A 1986
51KE2402 2A 1986
524032EK 2A 1986
52KE2403 2A 1986
52KE2406 2A 1986
566122EK 2A 1986
56KE2600 2A 1985
56KE2610 2A 1986
56KE2612 2A 1986
56KE2615 2A 1986
597032EK 2A 1986
597062EK 2A 1986
59KE2703 2A 1986
59KE2706 2A 1986
668002EK 2A 1986
668102EK 2A 1986
668122EK 2A 1986
66KE2800 2A 1986
66KE2802 2A 1986
66KE2805 2A 1985
66KE2810 2A 1986
66KE2812 2A 1986
66KE2815 2A 1986
66KE2822 2A 1986
689032EK 2A 1986
689062EK 2A 1986
68KE2903 2A 1986
68KE2906 2A 1986
215054EK 2B 1987
215924EK 2B 1987
215954EK 2B 1987
21CE4250 2B 1986
21CE4256 2B 1986
21CE4259 2B 1987
21CE4550 2B 1986
21CE4551 2B 1986
21CE4556 2B 1986
21CE4557 2B 1987
21CE4559 2B 1987
21CE5551 2B 1988
21CE5554 2B 1988
22AV1112 2B 1986
22AV1113 2B 1986
22AV1121 2B 1986
22AV1131 2B 1986
247054EK 2B 1986
247924EK 2B 1987
247954EK 2B 1987
24CE4270 2B 1986
24CE4271 2B 1986
24CE4272 2B 1986
24CE4273 2B 1986
24CE4276 2B 1986
24CE4279 2B 1987
24CE4570 2B 1986
24CE4571 2B 1986
24CE4572 2B 1986
24CE4573 2B 1986
24CE4576 2B 1986
24CE4577 2B 1987
24CE4579 2B 1987
257325EK 2B 1988
257355EK 2B 1989
25CE5270 2B 1988
25CE5570 2B 1988
25CE5571 2B 1988
25CE5573 2B 1988
25CE5574 2B 1988
25CE5575 2B 1988
279054EK 2B 1986
279924EK 2B 1987
279954EK 2B 1987
27CE4290 2B 1986
27CE4291 2B 1986
27CE4292 2B 1986
27CE4293 2B 1986
27CE4295 2B 1987
27CE4296 2B 1986
27CE4297 2B 1986
27CE4298 2B 1988
27CE4299 2B 1988
27CE4391 2B 1986
27CE4392 2B 1986
27CE4590 2B 1987
27CE4591 2B 1986
27CE4592 2B 1987
27CE4593 2B 1986
27CE4596 2B 1986
27CE4598 2B 1988
27CE4599 2B 1988
27CE4690 2B 1986
27CE4691 2B 1986
27CE4692 2B 1986
27CE4695 2B 1987
27CE4696 2B 1987
27CE4697 2B 1988
27CE4698 2B 1988
289325EK 2B 1988
289355EK 2B 1989
28CE5290 2B 1988
28CE5298 2B 1988
28CE5590 2B 1988
28CE5591 2B 1988
28CE5592 2B 1988
28CE5593 2B 1989
28CE5594 2B 1989
28CE5595 2B 1988
28CE5597 2B 1989
525024EK 2B 1986
52KE4502 2B 1986
52KE4505 2B 1986
52KE4535 2B 1988
52KE4562 2B 1986
52KE4565 2B 1986
52KE4592 2B 1987
52KE4595 2B 1987
597024EK 2B 1986
59KE4662 2B 1988
59KE4702 2B 1986
59KE4705 2B 1986
59KE4722 2B 1987
59KE4725 2B 1987
59KE4732 2B 1987
59KE4765 2B 1986
59KE4775 2B 1987
59KE4792 2B 1987
59KE4795 2B 1987
63KE5722 2B 1988
63KE5725 2B 1988
63KE5735 2B 1988
63KE5755 2B 1988
63KE5765 2B 1988
63KE5775 2B 1988
63KE5792 2B 1988
63KE5795 2B 1988
689024EK 2B 1986
689054EK 2B 1986
689064EK 2B 1986
68KE4902 2B 1986
68KE4905 2B 1986
68KE4906 2B 1986
68KE4922 2B 1987
68KE4923 2B 1987
68KE4925 2B 1987
68KE4932 2B 1987
68KE4962 2B 1986
68KE4965 2B 1986
68KE4966 2B 1986
68KE4975 2B 1987
68KE4986 2B 1987
68KE4992 2B 1987
68KE4995 2B 1987
68KE4996 2B 1987
70KE5922 2B 1988
70KE5925 2B 1988
70KE5935 2B 1988
70KE5975 2B 1988
70KE5992 2B 1988
70KE5995 2B 1988
