Eddystone 1830-1 bj. 1971 19 inc. versie (zeldzaam) aangeboden. (Aangeboden)
door A. Ouwehand @, Amersfoort, 18-04-2015, 13:34 (4022 dagen geleden) @ A. Ouwehand
Bij deze nog info over de ontvanger:
Country: Great Britain (UK)
Manufacturer / Brand: Eddystone, Birmingham
alternative name
Stratton & Co.Ltd.; Birmingham
Year: 1971–1977 Type: Communication/Commercial Receiver (also Amateur)
Semiconductors (the count is only for transistors) 33:
Principle Superhet, double/triple conversion; ZF/IF 1350/100 kHz
Wave bands Broadcast, Long Wave and more than two Short Wave bands.
Details
Power type and voltage Alternating Current supply (AC) / 100-130 / 200-260 / 12 Volt
Loudspeaker Permanent Magnet Dynamic (PDyn) Loudspeaker (moving coil)
Power out 1.5 W (unknown quality)
from Radiomuseum.org Model: 1830/1 - Eddystone, Birmingham
Material Metal case
Shape Tablemodel, with any shape - general.
Dimensions (WHD) 502 x 164 x 376 mm / 19.8 x 6.5 x 14.8 inch
Notes General coverage receiver, covering 120 khz - 31 MHz in 9 bands (120-250 / 240-480 / 480-950 / 920-1750 kHz, 1,5-2,9 / 2,9-5,5 / 5,5-10 / 10-19 / 18-31 MHz); AM, CW, USB/LSB.
10 crystal controlled preset channels. Optional plint loudspeaker unit 989 or cabinet speaker 935, optional anti-vibration mounting LP-2817/2
Standard production version, approved by MPT as Marine Reserve Receiver.
Also sold as S.A.I.T. MR1431 and under Hagenuk Label.
Net weight (2.2 lb = 1 kg) 18.1 kg / 39 lb 13.9 oz (39.868 lb)
