TEC Skylark Model: NR-52F1 met o.a. SSB. (Aangeboden)
door A. Ouwehand @, Amersfoort, 15-05-2015, 14:01 (3996 dagen geleden)
Country: Japan
Manufacturer / Brand: Tokyo Electric Co. (TEC); Tokyo
alternative name Matsuda
Year: 1975 ?? Type: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) 17:
Principle Superhet, double/triple conversion
Wave bands Wave Bands given in the notes.
Details
Power type and voltage Line / Batteries (any type) / 110-220 / 12 Volt
Loudspeaker Permanent Magnet Dynamic (PDyn) Loudspeaker (moving coil) - elliptical
Power out
from Radiomuseum.org Model: Skylark NR-52-F1 - Tokyo Electric Co. TEC; Tokyo
Material Modern plastics (no Bakelite or Catalin)
Shape Portable set > 8 inch (usable without mains)
Dimensions (WHD) 400 x 275 x 125 mm / 15.7 x 10.8 x 4.9 inch
Notes AM-Empfangsbereich: 145 kHz - 30 MHz, FM 65-108 MHz, VHF ca. 145-175 MHz, UHF ca. 430 - 470 MHz: SW 1-4, AM, LW, MW, MB, AIR; Regler für Volume, Tone, Squelch, RF-Gain, LSB/BFO/USB, VHF-Double-Converter, 2 Antennen. Wurde auch unter dem Namen MARC mit gleicher Modell-Nr. vertrieben
Net weight (2.2 lb = 1 kg) 5.2 kg / 11 lb 7.3 oz (11.454 lb)
45 euro.
[image][image]
