Philip D2999 (Toestel of techniek)
door Maurice ⌂ @, Dordrecht, 14-05-2016, 19:38 (3638 dagen geleden) @ Phil Ireland
Gewijzigd door Maurice, 14-05-2016, 19:49
Phil
There are 3 modes for the tuning Rotating knop.
So check if you have choosen the app. setting.
Or type in direct the frequenty wanted.
So you can check if the SW band it self is OK.
Also first wire that antenne wire correctly, probably a faulty
position will cause problems.
Antenne Wire.
After Downloading service manual go to page 9.
Left top the drawing-A is the telescope antenne drawn as a real tellescope.
Look at circle (D6) and go to drawing D-left (the board it self)
Now Look for circle (A6) at top line and see the wire position at Coil 5005.
So D6 tot A6.
And now you know also how the drawing works for the Pilotlight problem.
Service manual:
After pressing the link WAIT for the tekst "..Prossesing.." to
turn to the tekst "..Get Manual"
Then tik that text and the PDF wil open.
Or download to your Harddisk.
http://elektrotanya.com/philips_d2999_sm.pdf/download.html
