Kenwood........ (Aangeboden)
door Mohawk ⌂ @, Ter Apel, 31-07-2016, 21:22 (3553 dagen geleden)
Uitdaging voor de super techneut!
(Of voor onderdelen......)
Héél grote en zware tuner/versterker.
Geen geluid meer, voeding is O.K.
Veel doc. op schijf meegeleverd.
Voor €20,00 .
Versturen kan (>10kg), maar Liefst ophalen!
Woonplaats onderin de provincie Groningen.
Specs. audiodeel:
Kenwood KRF-X7775D Foto's zie onderaan.
Rated Output Power during stereo operation
20 Hz ~ 20 kHz, 0.7% T.H.D. , 6(IEC)
W
..........................................................................130W + 130 W
120 watts per channel minimum RMS, both channels
driven, at 6 from 20Hz to 20kHz with no more than
W
0.05% total harmonic distortion (FTC).
Effective Output Power during stereo operation
1 kHz, 10% T.H.D. at 6 W................................170 W + 170 W
Effective Output Power during surround operation, one
channel driven
Front
1 kHz, 10% T.H.D. at 6 W...............................180 W + 180 W
20 Hz ~ 20 kHz, 0.06% T.H.D. at 6 W..........150 W + 150 W
Center
1 kHz, 10% T.H.D. at 6 W...............................................180 W
20 Hz ~ 20 kHz, 0.06% T.H.D. at 6 W..........................150 W
Surround
channel driven (Front, Center, Surround)
1 kHz, 0.005% T.H.D. at 6 W.....................................95 W · 5
Total Harmonic Distortion.............0.005 % (1 kHz, 65 W, 6 )
W
Frequency Response (IHF’66)
Line (CD1, MD/TAPE, CD2/TAPE2 MONITOR, CD-R,
VIDEO 1 - 3, DVD/6CH.).........7 Hz ~ 100 kHz, 0 dB, -3 dB
Signal to Noise Ratio (IHF ‘66)
PHONO (MM)............................................................... 76 dB
CD1..................................................................................98 dB
Input Sensitivity / Impedance
PHONO (MM)................................................4.0 mV / 47 kW
CD1.................................................................300 mV / 47 k
W
DVD/6CH........................................................300 mV / 47 kW
Output Level / Impedance
TAPE REC.....................................................300 mV / 2.2 k W
PRE OUT (Front, Center, Surround, Surround back)
................................................................................1 V / 470 W
PRE OUT (Subwoofer).......................................1.8 V / 470
W
Tone Control
Bass............................................................ + 7 dB (at 100 Hz)
Treble......................................................... + 7 dB (at 10 kHz)
Loudness Control
Volume at -30 dB level.......+6 dB (100 Hz), +3 dB (10 kHz)
M.v.g. Wim
