wat is dit voor een apparaat? (Toestel of techniek)
door soundman2 @, Wouw, 04-09-2017, 11:08 (3159 dagen geleden) @ kris
Op het www vond ik dit artikel:
Magicubes (X-Flashcubes) were an improvement on flashcubes, introduced in 1970. They looked almost identical to the original flashcubes, but were fired mechanically by a small bar striking a pin coated in fulminating material. This simplified the system compared to flashcubes - by removing the need for a battery, and made extremely cheap flash cameras possible. Magicube sockets appeared similar to flashcube ones, but had a slightly larger slot and were distinguished by being marked with an X - similarly the cubes themselves usually had a large X on the top - and having a pin instead of electrical contacts.
Een slagpinnetje wat ontstekingsmateriaal raakt.
Wat nu precies het ontstekingsmateriaal was wordt niet verteld, maar een luciferkop die met kracht wordt aangeslagen geeft ook een flinke vonk.
