Philips D2999 Wereld ontvanger AM/FM/SSB. (Aangeboden)
door A. Ouwehand @, Amersfoort, 29-01-2018, 14:35 (3006 dagen geleden)
Heeft wat uiterlijke gebruiksporen.
150 euro.
Country: Netherlands
Manufacturer / Brand: Philips; Eindhoven (tubes international!); Miniwatt
Year: 1986 Category: Broadcast Receiver - or past WW2 Tuner
Semiconductors (the count is only for transistors) 70: BD136 BF199 BF245 BF324 BF410 BF982 BFY90 ED1402 ED1502 ED1602 ED1802 2SB324 TCA440 TDA1011 TDA5700
Main principle Superhet, double/triple conversion; ZF/IF 55000/468/10700 kHz
Wave bands Broadcast, Long Wave, Short Wave plus FM or UHF.
Details
Power type and voltage Line plus power jack, mostly with battery or storage battery / 220; 240 / 6 x 1,5 / 12 Volt
Loudspeaker 2 Loudspeakers / Ø 15 cm = 5.9 inch
Power out 7 W (unknown quality)
from Radiomuseum.org Model: D2999 /00 - Philips; Eindhoven tubes
Material Modern plastics (no Bakelite or Catalin)
Shape Portable set > 8 inch (usable also without mains)
Dimensions (WHD) 320 x 100 x 250 mm / 12.6 x 3.9 x 9.8 inch
Notes
SW-coverage 146-26100 kHz, AM/SSB with BFO, digital frquency readout, 16 memories, clock/timer. In USA sold under Magnavox-label. 16 frei belegbare Senderspeicher. Anzeige-lnstrument für Signalstärke bzw. Batterie - Test. Schalter für Nah-/Fernempfang. Hochfrequenz - Verstärkungsregler. Schaltbare BFO-Einheit für SSB - Empfang. Digitaluhr mit 12/24-StundenAnzeige.
Each semiconductor type listed once.
Net weight (2.2 lb = 1 kg) 3.7 kg / 8 lb 2.4 oz (8.15 lb)
Price in first year of sale 990.00 SFr.
