Owon AG1011F functiegenerator nieuw! (Aangeboden)
door Leo Snoeren ⌂ @, Dongen, 18-06-2022, 09:42 (1402 dagen geleden) @ Leo Snoeren
Deze nieuwe functiegenerator van Owon, type AG1011F:
Getest en perfect werkend!
Model AG1011F
Channel single + trigger
Frequency Output 10MHz
Sample Rate 125MS/s
Vertical Resolution 14 bits
Standard Waveform Sine, Square, Pulse, Ramp, and Noise
Arbitrary Waveform Exponential Rise, Exponential Fall, Sin(x)/x, Step Wave, and others, total 45 built-in waveforms, and user-defined arbitrary waveform
Amplitude 1m Vpp - 12.5 Vpp (50Ω), 1m Vpp - 25 Vpp (high impedance)
Resolution 1m Vpp, or 4 digits
DC Offset Range (AD+DC) ±6.25V (50Ω), ±12.5V (high impedance)
DC Offset Range Resolution 1mV, or 4 digits
Load Impedance 50Ω (typical)
Wave Length 2 pts to 8K pts
Sample Rate 125MS/s
Non-volatile Memory 64M bytes
Modulation Waveform AM, FM, PM, FSK, Sweep, and Burst
Modulation Frequency 2mHz to 20.00KHz (FSK 2mHz - 100KHz)
Communication Interface USB device
Dimension (W x H x D) 235 x 110 x 295 (mm)
Device Weight 3.00 kg
Zie voor meer informatie en betere foto's diverse verkoopsites op internet.
150 euro
