pcb bescherm laag (Toestel of techniek)
door Maurice ⌂ @, Dordrecht, 10-06-2025, 22:12 (406 dagen geleden) @ electron
KONTAKT CHEMIE-PLASTIK-70
PLASTIK 70 is a quick drying, colourless transparent insulating and protective coating based on acrylic resins. PLASTIK 70 is a low viscosity, solvent drying acrylic based conformal coating with excellent insulating properties.
Contains “moisture warning”: To avoid involuntary encapsulations of moisture, Plastik 70 will warn you when applied on a humid surface, by showing a frosted, mat appearance.
For repair works PLASTIK 70 can be soldered through or be totally removed with acetone, THINNER FOR PLASTIK 70.
PLASTIK 70 was specially developed to protect printed circuit boards.
It overcomes electrical leakages and short circuits.
As a low viscosity fixing and insulating lacquer, PLASTIK 70 can also be used as extra/after insulation of coils and transformers and overcomes disturbing noises.
PLASTIK 70 can also be used as a universal protective coating on any surface like metal, paper, ornaments, paintings, furniture, etc.
