Philips Microfoon N8306 openen? (Algemeen)
door Rolf Zetterberg @, 16-06-2025, 19:19 (308 dagen geleden) @ Rolf Zetterberg
A more detailed description:
Carefully pry off the Philips badge.It is glued.
Then remove the ring-the ends are very slightly bent in when mounted at the factory.
Now you will see 3 tiny screws.Remove them completely and then it's possible to remove the mic element from the case.
Took some pictures,but sadly the camera stopped working.
