LLDB3-TP trigger diode (Algemeen)
door Jordan22xx @, 14-10-2025, 19:57 (186 dagen geleden)
Gewijzigd door Forumbeheer, 14-10-2025, 20:21
Hey everyone,
I’m still pretty new to electronics, and I’ve been learning by building small AC control circuits lately. I just found an LLDB3-TP trigger diode and I’m curious if it’s a good choice for a simple lamp dimmer project I’m trying to make for school.
From what I’ve read, it’s a diac that helps trigger a TRIAC at around 30V, but I’m still not sure how stable it is in real setups. Does the trigger voltage change much over time or temperature? And if the circuit picks up noise from the mains, can that cause random firing or flickering?
I’m planning to mount it close to the TRIAC on a small perf board, but I’m not sure if that’s ideal. Any tips on placement or wiring would be super helpful. If anyone here has used the LLDB3-TP (or a similar diac) in dimmer or AC motor control circuits, I’d love to hear how it performed and what I should watch out for.
I’m trying to learn by doing, so any advice from you guys who’ve been at this longer would really help!
Thanks!!!
