FP15R12W1T4 IGBT in my DIY inverter (Algemeen)
door Jordan22xx @, 20-10-2025, 18:37 (183 dagen geleden)
Gewijzigd door Forumbeheer, 11-11-2025, 20:51
Hey everyone,
I’m building a small DIY inverter to power my workshop lights, and I chose the FP15R12W1T4 IGBT. It looks ideal (1200 V, 15 A), but I’m running into some snags and could use your help.
Here’s what’s happening:
The IGBT switches fine during no-load testing, but once I hook up actual lamps, I start to see weird voltage spikes on the collector and occasional dropouts. I’ve tried snubber RC and stacking MOVs, but spikes still appear when I switch on inductive loads. My gate drive uses 15 V with 10 Ω resistor; layout shows some long traces around the IGBT + diodes.
Does anyone here have experience using FP15R12W1T4 (or similar IGBTs) in inverter builds? Would love to hear how you dealt with:
Gate drive optimization (resistor values, bootstrap / floating gate)
Layout tips for minimizing voltage overshoots / ringing (trace length, ground layout)
Snubber / clamping strategies that reliably stabilize the IGBT under load
Thanks much!
door soundman2 @, Wouw, 21-10-2025, 15:40 (182 dagen geleden) @ Jordan22xx
A capacitive or inductive load can be a problem for a switcher.
