Help,autoradio 22rn661 like to two parts,LMCUU model erased .... 4A, manufacture France Spain?, 12 and 24v, some information please, thanks
Quini
Schema 22RN661 is aan schematheek toegevoegd
door Forumbeheer , Delft / Haarlem, 15-06-2010, 21:52 (5072 dagen geleden) @ quini60
For the diagram of this carradio see "schematheek". (link is also in the upperright corner of this screen)
Met dank aan Emile van de Kerkhof (Radiodatabase.nl) is dit schema aan de schematheek toegevoegd.
Forumbeheer
door quini60 , Spain, 16-06-2010, 16:34 (5071 dagen geleden) @ Forumbeheer
hallo, ik heb deze regeling, maar het is een zeer vergelijkbaar model met losse verbindingen, 12-24V, (...... model 4a). LMCUU niet LMKUU. bedantk
door Maarten Bakker , Haarlem/Delft, 16-06-2010, 17:37 (5071 dagen geleden) @ quini60
In that case, behind the 22RN661 number should be a / with another 2 digit number which is not the same as on the schematic.
philips autoradio LMCUU
door soundman2 , Wouw, 17-06-2010, 12:39 (5070 dagen geleden) @ quini60
Quini
Quini,
Is this the radio you are searching for? Only 6 and 12 volts
http://www.tsf-philips.org/documentations%20de%20service%20autoradios.html
Probably there is another model, intended for touringcars and so on, called "PHILITOURING". Almost 12 or 24 volts and possible to drive many loudspeakers.
no further documents
door quini60 , Spain, 18-06-2010, 18:02 (5069 dagen geleden) @ soundman2
Hi,it may be a model of Spanish manufacture; lmCuu not lmKuu, model (..... 4A).Like externally is 22rn661. and can not find anything information. Thanks
Quini
door Maarten Bakker , Haarlem/Delft, 19-06-2010, 04:46 (5069 dagen geleden) @ quini60
Waht do you mean by 4A? Do you have a full model number and serial number?
door quini60 , Spain, 19-06-2010, 09:26 (5069 dagen geleden) @ Maarten Bakker
Hi Maarten,philips model ....... 4A, the rest is removed. thanks.
quini
door soundman2 , Wouw, 24-06-2010, 06:52 (5064 dagen geleden) @ quini60
The five characters, are that those on the push-buttons.
It seems the indication for the presets on various wavebands
L= longwave
M= medium wave
K= shortwave, in german Kurzwelle. other countries probably written with C
U U= two times FM preset (Ultrakurzwelle, UKW or Ultra Short, FM.
Its only a suggestion
Henk Roovers
