Gezocht lijntrafo of TV van Erres, type 16 1422TK (Gezocht)
door Lammert , Ermelo, 23-11-2020, 20:56 (1250 dagen geleden)
Wie kan mij helpen aan een goede lijntrafo of een goedwerkend TV-tje van Erres, type 16 1422TK?
Zie foto's hieronder.
Prijs komen we wel uit.
M.v.g.,
Lammert
door Maurice , Dordrecht, 23-11-2020, 22:10 (1250 dagen geleden) @ Lammert
Gewijzigd door Maurice, 23-11-2020, 22:13
161422TK CTX-E 1984
chassis is dus van type CTX-E
ken ik zo niet snel.
vraag is of identiek is aan K40 trafo??
ideeen:
Philips CTO/CTX To reset settings With set sw'd on s/c the left hand side of R3017 to the bottom of R3014
Philips CTX Dead R3394 R3395 OC 27k 2.5W
Philips CTX Dead crack in print at corner of remote psu
Philips CTX Dead R3298 4R7 dropper o/c
Philips CTX Dead - buzzing from psu & spkr HT ok - IC7375 TDA2577 u/s
Philips CTX Dead - HT low at 50v Trs7322 & 7323 BC548 & BC558 faulty - (read ok)
Philips CTX Dead - no 125v, faint whine from psu D6317 1N4148 leaky
Philips CTX Dead - overload on LOP EHT lead s/c
Philips CTX DEAD SET SCREAMS AND BLOWS LINE OP TRANSISTOR IF L C2351 CHOPPER TRANSISTOR BASE COUPLER 4u7
Philips CTX Dead with whistle - ok on dummy load Dry joints C2609
Philips CTX Dead. Check R3394/3395 27k , 2.5W for o/c.
Philips CTX EHT & CRT heaters ok but no raster & loud hum fro R3585 ( 2R2 ) o/c
Philips CTX Field scan noisy Q541(2SD1266) Ripple Filter Tr S/C. (used BUT11AF in lieu)
Philips CTX Frame - picture Jitter. Drys around LOPTX
Philips CTX Frame collapse - Intermittent. Check connections around LOPTX
Philips CTX Int colour TDA3560
Philips CTX Int dead Dry joints LOPTx
Philips CTX Int no startup - stations will not store. Battery.
Philips CTX LINE INSTABILITY ON VCR PLAYBACK ADJUST AGC PRESET R3144
Philips CTX Line tearing at top - worse on VCR. C2378 ( 1uf ) dried up.
Philips CTX LINE TR SC REPLACEMENT BLOWS AFTER 1 WEEK C2531 IN CHOPPER CCT LOW
Philips CTX Losing memory. Check for dry on or faulty 2.4v cell 1777.
Philips CTX LOW WIDTH AND BOWED RIGHT HAND SIDE R3483 6.2ohm o.c DRIVE TO DIODE MODULATOR
Philips CTX MEMORY LOSS ( CHANGED BATTERY ) M5840 MEM IC
Philips CTX NO COLOUR + POOR GREYSCALE PIN 1 TDA3650 LOW ( NORMALLY 9v ) R3222 HIGH 10R
Philips CTX No colour at switch on. Poor connection on TDA3560 holder.
Philips CTX NO COLOUR FROM COLD , GRADUALLY INCREASES TDA3650 LOOSE IN SOCKET
Philips CTX no field sync 2 hi value Rs in field sync cct o/c
Philips CTX No pic - sound ok S/Castle pulse low at pin 8 of TDA3560; TDA2577 faulty
Philips CTX No pic - sound ok R3584 47R fusible o/c
Philips CTX No pic/sound - field collapse seen when A1 advanced 12v safety res feed to field chip o/c
Philips CTX No picture - EHT ok. R35hm ( 2.2R ) o/c.
Philips CTX No sound No lt supply to audio o/p chip - R3170 3R3 o/c
Philips CTX No sound or picture. R3327 ( 120k ) o/c may be the set HT control.
Philips CTX No sound/pic - small pic when A1 advanced R3327 120K o/c
Philips CTX No timebase operation. Drys on pin 12 of LOPTX.
Philips CTX No/little colour Hi res joints on TDA3560 chip holder
Philips CTX POWER SUPPLY DEAD C2323 220uF 10v
Philips CTX Raster - small raster. R3327 ( 120k ) o/c may be the set HT control.
Philips CTX Set dead 125V ok Check for square wave at pin 11 TDA2577 if missing replace T7353 ( BF422 )
Philips CTX Sound - buzzing alters with picture content. Radiation - via unscreened audio lead.
Philips CTX Startup - no start up - Intermittent on/off R3325 set HT pot dirty.
Philips CTX Tripping D6583 SC
Philips CTX Tripping. D6590 ( BYV95A ) s/c.
Philips CTX Wrong cols - Red = purple, blue = red, grey scale ok was degauss therm dry jointed
Philips CTX-E Won't stop in search tune mode Pin 1 LM339N IC7830 not going low when search button pressed - chip faulty
Philips CTX-S Black lines across col pic - ok in b/w C2218 2µ2 63v
door Cornelisjan , Lunteren, 23-11-2020, 23:20 (1250 dagen geleden) @ Maurice
Gewijzigd door Cornelisjan, 23-11-2020, 23:26
Lammert/Maurice,
Heb wat gevonden, nog nieuw ook.
Het mooiste is als het Philips bestelnummer klop nl. 4822 140 102 36.
Op doosje staat TX5 en CX5 Chassis?
door Maarten Bakker , Haarlem/Delft, 24-11-2020, 00:09 (1250 dagen geleden) @ Cornelisjan
De chassis die op het doosje staan, bestaan niet en het nummer op de trafo zelf is anders. Toch verwijst Aswo wel naar deze trafo voor het CTX-E chassis. Ik weet niet zeker of er verschillende trafo's gebruikt zijn die niet uitwisselbaar zijn, maar ik dacht eigenlijk van niet. Dan zou hij dus moeten werken.
Ik heb zelf ook nog een andere trafo met servicenummer 4822 140 10395 liggen als het goed is, die ook naar voren komt als je op het CTX-E chassis zoekt.
door Cornelisjan , Lunteren, 24-11-2020, 00:31 (1250 dagen geleden) @ Maarten Bakker
Gewijzigd door Cornelisjan, 24-11-2020, 00:41
Maarten,
Hoe werd jij ook weer genoemd, onze huisnumeroloog
Ik kende de chassis TX5 / CX5 ook niet vandaar dat ik er al een vraagteken bij had gezet.
Waarom de vorige eigenaar dit op het doosje heeft gezet is mij dus een raadsel.
Een ander opvallend punt is dat bij de trafo op de foto door de kern 2 draadeinden uitsteken en mogelijk met 2 moertjes de montage op de print verstevigen. (maar 1 zichtbaar op foto)
Zijn deze draadeinden bij jouw exemplaar ook aanwezig?
Verder kan Lammert nog naar pennen kijken of dit overeenkomt.
Cor
door Maurice , Dordrecht, 24-11-2020, 00:56 (1250 dagen geleden) @ Maarten Bakker
Gewijzigd door Maurice, 24-11-2020, 01:06
TX,TX2,TX3,TX3F Bestaan als ook TX-E
140602TK CTX-E 1982
14CT2006 TX-E 1982
Laat E nu 5e letter zijn.
Dat een idee?
Trafo 2248 140 10236 kom ik uit op een CTXS
482214010236 PHILIPS 16CT2016 CTXS CHASSIS
Of wel de Diemen versie HD6096
Wel keurig met schema er bij.
Kennelijk geleverd met 2 soorten chassis.
16CT2016 CTX-S 1982
16CT2016 TX-E 1982
EN de
20CT2036 CTX-E 1982
HR6096 482214010236 PHILIPS 16CT2016 CTXS CHASSIS 20CT2036 / 51KT236007
Ik zeg die trafo is geschikt.
Dat is boffen.
door Maarten Bakker , Haarlem/Delft, 24-11-2020, 01:19 (1250 dagen geleden) @ Maurice
Gewijzigd door Forumbeheer, 24-11-2020, 01:47
TX is de aanduiding voor zwart/wit chassis, en daar nummerden ze maar door tot 3. TX-E is een schrijffout voor CTX-E. CX5 kan een deel van een typenummer zijn, maar ook dat bestaat niet. Zal inderdaad wel een verbastering zijn van CTX-E en CTX-S, misschien door het zaterdaghulpje geschreven.
CTX-S is de in Singapore geproduceerde variant, CTX-E is in België en Engeland gemaakt, misschien ook nog wel in Spanje of Italië.
Het kan dat de trafo's van CTX-E en CTX-S oorspronkelijk verschillend waren, dat weet ik niet zeker. In elk geval lijkt het erop dat dit een CTX-E toestel en een CTX-E trafo zijn. Dus als de pinout overeenkomt zou ik het er ook op wagen.
door Cornelisjan , Lunteren, 24-11-2020, 01:27 (1250 dagen geleden) @ Maurice
Gewijzigd door Cornelisjan, 24-11-2020, 01:29
Echt indrukwekkend zoveel kennis op dit Forum aanwezig is, geweldig.
Lammert kan aan de slag.
Maurice en Maarten tot zover bedankt.
door Lammert , Ermelo, 24-11-2020, 19:10 (1249 dagen geleden) @ Cornelisjan
Heren,
Dank voor jullie reacties en Cornelisjan, de trafo op de foto is hem. De aansluitingen zijn identiek.
Graag zou ik deze trafo van je willen overnemen. Zie je mail.
Maarten: welke andere trafo bedoel je?
Lammert
door Cornelisjan , Lunteren, 24-11-2020, 20:30 (1249 dagen geleden) @ Lammert
Beste Lammert,
Mooi dat je gecontroleerd hebt dat de aansluitingen enz, overeenkomen.
Zoals je gezien hebt, hebben bovendien 2 zeer ervaren specialisten ook geconcludeerd dat deze trafo voor jouw de juiste is.
Ik heb zonet gereageerd op jouw ontvangen mail.
Cor
door Maurice , Dordrecht, 24-11-2020, 21:42 (1249 dagen geleden) @ Lammert
Lammert,
Controleer voor zekerheid even via de link het schema van de trafo
en vergelijk met het schema.
99,9% overtuigd dat het dezelfde trafo is.
Maar voor je probeert en zoekt naar fouten.
Controleer ook vooraf vervangen van de trafo of de aansturing geen fouten heeft.
Componenten die daar mee te maken hebben.
Bekijk ook even de toegestuurde fouten lijst welke voorgekomen zijn in jouw
type toestel.
Mogelijk zitten er zaken tussen die je extra kunt controleren.
bv CTX-S Black lines across col pic - ok in b/w C2218 2µ2 63v
door Forumbeheer , Delft / Haarlem, 25-11-2020, 13:08 (1248 dagen geleden) @ Lammert
De trafo die ik volgens mijn bestanden heb liggen, heeft een ander servicenummer. Er zijn dus minstens 2 verschillende trafo's in omloop voor de service.
Jouw oude trafo en de trafo die je aangeboden wordt, verschillen op 1 relevant cijfer in het fabrieks-codenummer dat erop staat. De trafo's zijn gelijktijdig of kort na elkaar ontworpen.
Er is dus iets anders, maar bij mijn weten zitten er geen hiervoor belangrijke verschillen tussen CTX-E chassis. Ik denk dat het goedgaat maar ik houd een kleine slag om de arm.
Er zit toch niet toevallig verschil in de diameter van de hoogspanning- of focusaansluiting of iets dergelijks?
door Cornelisjan , Lunteren, 25-11-2020, 14:45 (1248 dagen geleden) @ Forumbeheer
Gewijzigd door Cornelisjan, 25-11-2020, 15:09
Ik weet niet Maarten of je de trafo makkelijk kunt vinden maar ik was eigenlijk benieuwd of bij jouw exemplaar ook draadeinden uitsteken voor montage met 2 moertjes voor montage versteviging.
Bij Lammert zijn deze moertjes aanwezig heeft hij mij gemeld.
Voedings- en hoogspanningsproblemen zijn niet de meest eenvoudige problemen van televisies.
Eerst moet je erachter zien te komen wat voor chassis het is.
Dan Zijn er vaak nog de nodige modificaties, welke via de bekende gele bladen worden doorgegeven.
Dan moet je een goed (blok)- schema, layout en zeker niet onbelangrijk een cirquit beschrijving hebben.
Vervolgens meet -technisch vaststellen waar de oorzaak zit van het niet werken van dit apparaat.
We zijn het er denk ik allemaal wel over eens dat zomaar onderdelen vervangen vaak teleurstellingen opleveren.
In plaats van oplossen worden er in het ergste geval problemen bij gemaakt met alle gevolgen van dien. De laatste tips van Maurice hinte hier denk ik ook op, en terecht.
Ik heb nog contact met Lammert gehad en hij heeft gemeld dat hij samen met een ervaren tv reparateur vastgesteld heeft dat de lijntrafo defect is.
Dus heb ik met een gerust hart de trafo naar hem opgestuurd.
Ik ben benieuwd hoe dit verder gaat maar Lammert laat het ons vast wel weten.
door Maarten Bakker , Haarlem/Delft, 25-11-2020, 15:09 (1248 dagen geleden) @ Cornelisjan
Ik denk dat mijn exemplaar is uit de tijd dat Philips al HR-vervangers leverde, dus dan zeggen die details ook niet zoveel. Ik moet mijn lijntrafo's binnenkort nog even ordenen en goed toegankelijk maken, dan kijk ik alsnog even.
Overigens was het behoorlijk zeldzaam dat deze stukgingen, maar na 36 jaar weet je het natuurlijk nooit. Ik hoop dat de monteur gelijk heeft.
door Roland Huisman , Zwolle, 25-11-2020, 15:21 (1248 dagen geleden) @ Maarten Bakker
Die trafo's zelf heb ik ook maar zelden defect gezien. Maar het zijn wel de eerste
verdachten om onder de print even door te solderen. Net als vermogenstransistoren
en andere componenten die warm worden. IC's even uit voetjes en weer in drukken,
om de zilveroxide er even af te schrapen, wil ook nog wel eens helpen.
Maar over het algemeen super betrouwbare toestellen...
Verder is het toch vooral meten.
Groeten, Roland
door Lammert , Ermelo, 25-11-2020, 19:57 (1248 dagen geleden) @ Roland Huisman
Gewijzigd door Lammert, 25-11-2020, 19:59
Dag Roland en de anderen,
De tip van Roland had ik al uitgevoerd na eerder mailcontact hierover maar dat had geen resultaat.
Ik heb wat spanningen gemeten op de aansluitpunten van de lijntrafo.
Ik meet geen spanningen tussen de volgende pennen:
Tussen pen 1 en 2: 1 V
Tussen pen 3 en 5: 0 V
Tussen pen 4 en 12: 0 V
Tussen pen 6 en 18: 11 V
Pen 7 t.o.v. chassis: 0 V
Pen 8 t.o.v. chassis: 0,6 V
Over C 2482: 0 V
Op de aansluitpunten van de driepolige grote elko nr. 2330 in het hoofschema meet ik op A en B 0V en op C
305V.
Op A hoort 160V te staan en op B 125V, zo staat aangegeven op de print.
Aan de top van bijv. diode 6101 rechtsonder op de print meet ik ook niet de opgegeven 33V, maar 0V
Zie schema lijntrafo en complete schema hieronder:
De reperateur (HTS-elektonica) verteld mij dat de lijntrafo defect is omdat spanningen daaromtrent ontbreken.
Ik kan niet beoordelen of dat zo is want tv is niet zo mijn ding niet om dat te bepalen.
Misschien nog wat tips om een juist oordeel over die lijntrafo te vellen, of zou er toch meer aan de hand zijn?
Lammert
door Maarten Bakker , Haarlem/Delft, 25-11-2020, 20:07 (1248 dagen geleden) @ Lammert
Gewijzigd door Maarten Bakker, 25-11-2020, 20:09
Vergeet die trafo dan voorlopig maar even, die diagnose is gesteld alsof het een normale voedingstrafo is, maar zo werkt dat niet in een TV. 11V op pen 6 betekent dat je voedingsspanning inelkaar klapt. Dat kan een overbelasting zijn (en dat kan ook weer meerdere kanten op, zelfs alsnog de trafo), maar dat kan ook een voedingsfout zijn.
Je moet dan als eerste de steker van de horizontale afbuiging (naast de trafo, 2 draden en een draadbrugje, ik denk dat dat M9 moet zijn) losnemen en op een van de pennen waar het draadbrugje zat, moet dan een hogere spanning ergens rond 100V verschijnen. Eventueel belasten met een kleine gloeilamp voor de test. Ik zoek wel even een schema op wat ik er los naast kan houden terwijl ik typ.
door Lammert , Ermelo, 25-11-2020, 21:39 (1248 dagen geleden) @ Maarten Bakker
Ik heb idd daarvoor M9 losgenomen en op pen 4 meet ik 305 Volt gelijkspanning.
Die meet ik ook als de steker op de pennen geklikt zit. Met dat draadbrugje is dan ook de spanning op pen 2 aanwezig.
door Forumbeheer , Delft / Haarlem, 26-11-2020, 18:40 (1247 dagen geleden) @ Lammert
Even op het schema gekeken, mijn fout. Het doorverbindinkje zit meestal achter de voeding maar bij dit model vóór de voeding. 305V klopt dus, maar het is op die manier niet mogelijk om de voeding te testen. Ik zou zelf in de voeding gaan meten met lamp eraan en het doorverbindinkje overbrugd, maar ik denk dat je beter vooralsnog de foutzoekboom kunt nalopen.
Of nouja, één meting die ik bij zulke klachten vrijwel onmiddelijk doe nog voordat ik in de voeding ga zoeken, is met M9 nog steeds losgetrokken en het toestel uitgeschakeld, even in de diodestand van de meter over de emitter en collector van de lijnuitgang, TS7562 in het schema, beide kanten op meten. Dan weet je snel of er iets kortgesloten of laagohmig is.
door Cornelisjan , Lunteren, 25-11-2020, 22:21 (1248 dagen geleden) @ Maarten Bakker
Gewijzigd door Cornelisjan, 25-11-2020, 23:12
Heb even in service doc gekeken en zag dat er een foutzoekboom is opgenomen.
Misschien goed om die ook even te bekijken.
Edit:
Foutzoekboom bij A:
Geen beeld ==> geen geluid ==> gloeidraad beeldbuis gloeit niet ==> 300V DC op C2330a ==>
125V DC op C2330b ==> hierna krijg je 3 mogelijkheden enz.
door Cornelisjan , Lunteren, 26-11-2020, 17:59 (1247 dagen geleden) @ Cornelisjan
Nog even aanvullende informatie:
Lammert je gaf het volgende aan:
U C2330a = 0V
U C2330b = 0V
U C2330c = 305V
Je heb waarschijnlijk a en c verwisseld (spiegelbeeld print ?) aangezien als a = 0V kan c geen spanning hebben (hulpspanning uit lijntrafo)
Echter nu we weten dat C2330b praktisch 0V is kan je verder met de foutboom.
Er waren 3 mogelijkheden:
1 Voeding hikt of 2 U C2330b <100V of 3 U C2330 = 300V
U C2330 <100V ==> U 16-7375 = 8V hierna 2 mogelijkheden enz.
door Lammert , Ermelo, 26-11-2020, 19:31 (1247 dagen geleden) @ Cornelisjan
Ja, ik had A en C omgewisseld gemeten. (spiegelbeeld schema)
De draadboom langsgelopen en ik wam uit bij C 2395 die geheel kortgesloten was.
Deze vervangen en toen had ik weer geluid en beeld!
Lijntrafo niet kapot dus.
Dank voor jullie reacties en het meedenken met mij!
Lammert
door Maarten Bakker , Haarlem/Delft, 26-11-2020, 19:47 (1247 dagen geleden) @ Lammert
Mooi opgelost!
door Maurice , Dordrecht, 26-11-2020, 22:40 (1247 dagen geleden) @ Lammert
Complimenten voor deze zoektocht.
Je ziet systematisch proberen te zoeken naar fouten.
Geweldig dat er weer beeld in zit, leuk
door Cornelisjan , Lunteren, 26-11-2020, 23:28 (1247 dagen geleden) @ Maurice
Mooi hoor, en Lammert zei: === tv is niet zo mijn ding === maar uiteindelijk heeft hij, met een klein beetje hulp van alle deelnemers van dit topic, het toch maar even zelf gedaan, top.
En ...... hij heeft nu een reserve trafo
door Dirk 1964 , Velsen, 03-12-2020, 21:25 (1240 dagen geleden) @ Lammert
De lijntrafo heb ik bij een CTX nog nooit defect gehad. Het zijn op een paar standaardfoutjes na zeer degelijke toestelletjes.
