<title>Nederlands Transistorforum - Philips audio amp board from the 60s</title>
<title>Philips audio amp board from the 60s (reply)</title>
<content:encoded><![CDATA[<p>I'm not sure how I managed to miss the code number on the solder side on this one five years ago (better late than never)...</p>
<p>It was made by Philips France, probably closer to 1965. Chances are, it's a phono amplifier.</p>
<p>Maybe Paul could forward this to the original poster, if his mail address is still in the database?</p>
<p>Meanwhile, I added the code number to my &quot;looking for&quot; index so additional information might turn up in another 5 years time <img src="images/smilies/wink.png" alt=";-)" /></p>
<link>https://www.transistorforum.nl/forum/index.php?id=21225</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=21225</guid>
<pubDate>Sun, 03 Aug 2014 20:41:33 +0000</pubDate>
<content:encoded><![CDATA[<p>From the way the board is built, I'd say it isn't from Philips. Maybe from an Italian manufacturer, but could be anything.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=1699</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=1699</guid>
<pubDate>Sun, 11 Oct 2009 22:35:56 +0000</pubDate>
<title>Philips audio amp board from the 60s</title>
<content:encoded><![CDATA[<p>Hello,</p>
<p>first post here... and I can't read dutch ! Sorry to have to write in english...</p>
<p>I have these pictures of a Philips (very probably) audio amp section. It comes from an unknown device (radio ? car radio ? recorder ? turntable ?...).</p>
<p><img src="http://i647.photobucket.com/albums/uu194/radioproject_album/Componentssidemod.jpg" alt="[image]"  /><br />
<img src="http://i647.photobucket.com/albums/uu194/radioproject_album/TracksSidemod.jpg" alt="[image]"  /></p>
<p>It is chassis ground negative... fairly uncommon these years, but I know that, for instance, some Philips radios, like L4X26T, P3X51T... were then already ground negative. </p>
<p>It uses 4 transistors (AC125, AC126 and 2 AC128s, in this order), and 2 transformers (a driver and an output transformer). It's a push/pull amplifier.  <br />
Transistors heatsinks are attached to the transformers. And the transformers are of the EI type.<br />
 <br />
Output power is around 0.75W. Works on 9V. <br />
 <br />
My guess would be... A Philips board, from 1963/1965 (from the transistors). But that's all I can say so far... I would like to know precisely what unit/device it comes from.</p>
<p>Would you recognize this board ? Or would you know someone who could help me identifying it ?</p>
<p>Thanks a lot for your help !</p>
<link>https://www.transistorforum.nl/forum/index.php?id=1683</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=1683</guid>
<pubDate>Sat, 10 Oct 2009 18:06:27 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>philipsradio</dc:creator>
