<title>Nederlands Transistorforum - Schakelaar 22RB192</title>
<title>Schakelaar 22RB192 (reply)</title>
<content:encoded><![CDATA[<p>This small transformer practically does not warm up, keep in mind that it uses only 3.5W from the outlet .... virtually zero.. a power meter will struggle to count the kWh ! =)<br />
 <br />
My Home Made LED electrification:<br />
<a href="https://www.flickr.com/gp/danielnogueira78/8WHC89">https://www.flickr.com/gp/danielnogueira78/8WHC89</a><br />
 <br />
Both bulbs were burned out<br />
 <br />
Daniel</p>
<link>https://www.transistorforum.nl/forum/index.php?id=39521</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=39521</guid>
<pubDate>Sun, 22 Oct 2017 09:52:47 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>Daniel Nogueira</dc:creator>
<content:encoded><![CDATA[<p>In hoeveel woningen staat de beltrafo altijd onder spanning? en hoe vaak veroorzaakt dit brand? Er is natuurlijk wel sprake van enig energieverlies door hat warm worden van de trafo.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=39518</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=39518</guid>
<pubDate>Sun, 22 Oct 2017 06:35:45 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>Jeroen Visser</dc:creator>
<content:encoded><![CDATA[<p>Hello !<br />
 <br />
Philips Fan here, writing from Portugal.<br />
 <br />
I believe that, back in those days, when there weren’t that much considerations about energy savings, this was quite common.<br />
 <br />
I have a 192, it was rescued from the skip ... it just needed  some contact cleaner in the volume potentiometer and the am-fm switch, and had the burn out lights. <br />
 <br />
I love to rescue old devices, and I love Philips, so .... I had to bring this one back to life !<br />
 <br />
I’ve replaced the old light bulbs with some nice warm white LED, less heat less power being used, and I’m using the 14v output so that the panel is lit up all the time now. Now I have a nice warm light in the kitchen, were I’ve placed it now.<br />
 <br />
<a href="https://www.flickr.com/gp/danielnogueira78/36zT71">https://www.flickr.com/gp/danielnogueira78/36zT71</a><br />
 <br />
<a href="https://www.flickr.com/gp/danielnogueira78/DGQd4q">https://www.flickr.com/gp/danielnogueira78/DGQd4q</a><br />
 <br />
<a href="https://www.flickr.com/gp/danielnogueira78/8791Z7">https://www.flickr.com/gp/danielnogueira78/8791Z7</a><br />
 <br />
Fun fact (for me!) is the 104 MHz end limit ! We have lots of stations here, between 104 and 108 and I simply cannot pick those in this radio ! <img src="images/smilies/smile.png" alt=":-)" /> <br />
 <br />
Greetings from Porto, Portugal <br />
 <br />
Daniel Nogueira</p>
<link>https://www.transistorforum.nl/forum/index.php?id=39515</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=39515</guid>
<pubDate>Sat, 21 Oct 2017 18:31:00 +0000</pubDate>
<content:encoded><![CDATA[<p>Hallo,</p>
<p>Zo'n schakelaar in het secundaire circuit mag alleen wanneer het opgenomen onder een zekere maat is (ik meen 25 W). Sluipverbruik valt nogal mee. Weliswaar zie je primair vaak een aardige stroom lopen (magnetisatiestroom) maar wanneer de schakelaar open staat is de cos phi heel klein en dus het opgenomen vermogen ook erg klein. Vaak moet je denken aan wel 15 VA, maar slechts 1 W.</p>
<p>Vr. gr. Huib.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=3382</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=3382</guid>
<pubDate>Mon, 26 Apr 2010 21:23:28 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>Huib</dc:creator>
<content:encoded><![CDATA[<p>Ik zou het nu geen tafelradio noemen in de klassieke zin van het woord; het is een piepklein printje in een veredelde schoenendoos, het einde van een tijdperk...</p>
<p>In de jaren 70 kwam de dubbele isolatie op (met als symbool twee vierkantjes in elkaar, wordt nog steeds gebruikt)  Ook hierdoor verdwenen netschakelaars uit toestellen.<br />
het schakelaartje in de 22RB192 zit samen met de volumeknop, deze is zeker niet geschikt voor 230~  (veel te klein)</p>
<p>anderzijds hebben de C-core transfo's van philips uit die tijd een merkwaardig hoog rendement (klein sluipverbruik) zal ik het eens meten?</p>
<p>Anderzijds, en dat was ook een deel van de vraag; tafelradio's uit de jaren 60 hadden wel een netschakelaar op 230~ . toen gebruikte men een klassiek klavier.</p>
<p>groeten</p>
<p>Kris</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2957</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2957</guid>
<pubDate>Mon, 15 Mar 2010 21:59:54 +0000</pubDate>
<content:encoded><![CDATA[<p>Dag Ed , </p>
<p>in sommige toestellen zit de schakelaar zelfs in het (secundaire) DC circuit . <br />
Kwam ik achter , bijv rekenmachine , zette er na stuk gaan een nette netschakelaar in , bleek na enige dagen zonder spanning soms eerst de voedingselko op gang te moeten komen , alvorens er uitlezing mogelijk was . </p>
<p>Waarom dit zo gedaan ?? Bij andere apparaten met een netvoeding EN aansluiting 12 volt is het nog logisch ,dan besparen ze een schakelaar door in sec DC die éne te plaatsen . <br />
Zag van dit apparaat een vroegere uitvoering met zowel een netschakelaar als schakelaar in de 12VDC , das ook even wennen <img src="images/smilies/wink.png" alt=";-)" />  <br />
m vr gr Huub</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2944</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2944</guid>
<pubDate>Sun, 14 Mar 2010 20:45:36 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>Huub</dc:creator>
<content:encoded><![CDATA[<p>Helemaal waar. Kijk maar eens naar het aantal toestellen (met name TV's) die een uitgefikte netschakelaar hebben.<br />
Een defecte voedingstrafo kom je volgens mij minder vaak tegen.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2937</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2937</guid>
<pubDate>Sun, 14 Mar 2010 14:10:24 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>Laurens</dc:creator>
<content:encoded><![CDATA[<blockquote><p>Ik bezit verscheidene draagbare transistoradio's die een netschakelaar bezitten.<br />
Echter , een veilige netschakelaar is groot en de 230 bedrading loopt door je radio heen, wat op zich ook risico's inhoud, daarom is het bij draagbare radio's dikwijls de gewoonte de radio met een laaspanningsschakelaar het zwijgen op te leggen.</p>
</blockquote><p>De 22RB192 is een tafelradio. Voor een degelijke netschakelaar is meer dan voldoende ruimte.</p>
<p>Dat de schakelaar in het laagspanningscircuit zit viel mij op omdat dit in vergelijkbare Philips radio's uit dezelfde tijd niet het geval is.<br />
Toch een bezuiniging?</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2936</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2936</guid>
<pubDate>Sun, 14 Mar 2010 10:09:52 +0000</pubDate>
<content:encoded><![CDATA[<p>Helemaal mee eens,</p>
<p>Kastje klein houden omdat extern een dikke netrafo-stekker zit, zo kan ik het ook.</p>
<p>Maar betreft de 22RB192, zeldzaam inderdaad.<br />
Zal wel een denkfoutje zijn in het ontwerp.<br />
Gebruikelijk is het zeker niet.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2935</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2935</guid>
<pubDate>Sun, 14 Mar 2010 10:03:17 +0000</pubDate>
<content:encoded><![CDATA[<p>(ps weet je dat een senseo ook altijd energie gebruikt0</p>
<p>Vandaar dat mijn vrouw altijd de stekker uit het stopkontakt haald na gebruik.<img src="images/smilies/smile.png" alt=":-)" /> <br />
grt. willem.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2934</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2934</guid>
<pubDate>Sun, 14 Mar 2010 09:26:07 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>Willem.H.N.</dc:creator>
<content:encoded><![CDATA[<p>De spijker op zijn kop kris<br />
Al dat gezeur over stanbay verbruik maar ondertussen heeft wel half nederland een hr ketel met confort stand (altijd te tap spiraal warm houden) en airco in zijn auto.<br />
Het zal mij benieuwen hoe dat in de toekomst met de elektrische auto gaat.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2933</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2933</guid>
<pubDate>Sun, 14 Mar 2010 08:39:53 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>snameroc</dc:creator>
<content:encoded><![CDATA[<p>Ik bezit verscheidene draagbare transistoradio's die een netschakelaar bezitten.<br />
Echter , een veilige netschakelaar is groot en de 230 bedrading loopt door je radio heen, wat op zich ook risico's inhoud, daarom is het bij draagbare radio's dikwijls de gewoonte de radio met een laaspanningsschakelaar het zwijgen op te leggen. Het sluipverbruik valt normaal gezien heel goed mee. Dit hangt vooral af van het rendement van de trafo. philipsen blijven onder de 0,5 watt. Bij een goede trafo met ingebouwde gevoelige thermische zekering en netzekering is er ook geen gevaar voor brand. (netschakelaars zijn voor brand gevaarlijker!)<br />
Dat een toestel in standby gaat in plaats van echt uit is op zich geen probleem als het goed doordacht is.</p>
<p>groeten</p>
<p>kris</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2932</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2932</guid>
<pubDate>Sat, 13 Mar 2010 23:49:41 +0000</pubDate>
<content:encoded><![CDATA[<blockquote><p>Misschien wordt er in Brussel al aan gewerkt, maar zo niet wordt het de hoogste tijd dat men in de EU eens aandacht besteedt aan al het onnodige verbruik van apparaten die niet helemaal kunnen worden uitgeschakeld.</p>
</blockquote><p>Dat zou zinvoller zijn dan het verbod op de gloeilamp. Wat krijg je er voor terug: juist ja (laagspannings)led lampen met voorschakelapparatuur (die ook nog een berg storing kan geven)....</p>
<p>Groeten,</p>
<p>Matthias</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2931</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2931</guid>
<pubDate>Sat, 13 Mar 2010 22:06:11 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>Matthias Meijer</dc:creator>
<content:encoded><![CDATA[<p>Allen bedankt voor de reacties.<br />
 </p>
<blockquote><p>heden toch bij 95% van alle apparaten het geval?</p>
<p>Ga maar na hoeveel apparaten nu in huis staan die niet meer een harde uitschakelaar hebben, of je moet erg zoeken.</p>
</blockquote><p>Dat was nu precies het bezwaar dat had toen ik dit radiootje openmaakte. Onnodig sluipverbruik en brandgevaar.<br />
Bij sommige toestellen heeft een stand-by schakeling nut, zoals een videorecorder. Bij andere toestellen als een tv of pc is het onzin.<br />
Daarom heb ik voor de toestellen die niet per se continu moeten aanstaan, deze op een stopcontactenblok met schakelaar aangesloten.</p>
<p>Of de vergelijking tussen nu en 40 jaar geleden opgaat waag ik te betwijfelen.</p>
<p>Bij een radio van 40 jaar oud -zonder afstandsbediening- is het niet afschakelen van de netspanning toch uitzonderlijk als ik andere Philips schema's uit de zelfde periode bekijk.<br />
Mijn eigen vermoeden is dat Philips bij dit radiootje voor een goedkope aan/uitschakelaar, die ongeschikt is voor netspanning, heeft gekozen om geld uit te sparen.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2930</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2930</guid>
<pubDate>Sat, 13 Mar 2010 20:11:53 +0000</pubDate>
<content:encoded><![CDATA[<p>Ed,</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2929</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2929</guid>
<pubDate>Sat, 13 Mar 2010 09:53:40 +0000</pubDate>
<content:encoded><![CDATA[<blockquote><p>Een Grundig radio uit begin jaren 80. Ook daar de voedingstrafo rechtstreeks op het net aangesloten, en secundair een aan/uit schakelaartje.</p>
<p>En dat is niet de eerste keer dat ik dit soort praktijken gezien heb. </p>
<p>Tegenwoordig is het natuurlijk helemaal feest met alle geschakelde voedingen in de meest uiteenlopende apparaten.</p>
<p>Groeten,</p>
<p>Matthias</p>
</blockquote><p>In simpele transistor radio´s met ingebouwde netvoeding is het heel gebruikelijk dat de net-trafo permanent spanning krijgt als de stekker in het stopcontact zit. Ook in ¨duurdere¨ hifi apparaten (cd spelers, ect) zie je heel vaak een net-trafo direkt doorverbonden met het netsnoer. De aan/uit schakelaar zit ergens verderop in het toestel.</p>
<p>Zoals Matthias al schrijft, in apparaten met geschakelde netvoedingen staan die meestal altijd aan zodra de netstekker wordt ingeplugd.</p>
<p>De enige oplossingen op dit euvel zijn of een externe 230 volt netschakelaar aanbrengen dan wel altijd de stekker er uit als men het apparaat niet gebruikt. Beide pas ik veelvuldig toe want het lijkt mij ook gunstig voor de levensduur van de voeding als deze ook echt van het net afgeschakeld is als het apparaat niet gebruikt wordt.</p>
<p>Met vriendelijke groet, Pieter.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2928</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2928</guid>
<pubDate>Fri, 12 Mar 2010 16:53:30 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>Pieter Vos</dc:creator>
<content:encoded><![CDATA[<p>Enige tijd geleden had mijn moeder de radio van haar oma op zolder terug gevonden. Een Grundig radio uit begin jaren 80.</p>
<p>Het ding kraakte wat met de schakelaars en potmeters, dus ik het opengeschroefd om die te reinigen. Ook daar de voedingstrafo rechtstreeks op het net aangesloten, en secundair een aan/uit schakelaartje.<br />
De voedingstrafo vond ik er ook niet bepaald robuust uitzien, dus maar de radio weer dichtgeschroefd en teruggezet waar hij vandaan kwam.</p>
<p>Groeten,</p>
<p>Matthias</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2927</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2927</guid>
<pubDate>Fri, 12 Mar 2010 11:54:17 +0000</pubDate>
<title>Schakelaar 22RB192</title>
<content:encoded><![CDATA[<p><img src="images/uploaded/201003121227414b9a333d4f650.jpg" alt="[image]" title="" /></p>
<p>In de Philips radio 22RB192 zit de aan/uitschakelaar achter de secundaire wikkeling van de voedingstrafo (2 x SK-B).<br />
Ik vind dit een nogal onveilige situatie. Een radio die altijd aan staat, ook al is het maar gedeeltelijk, heeft het risico van brand in zich.<br />
Het heeft ook geen enkel nut.</p>
<p>Komt dit bij meer toestellen voor?</p>
<link>https://www.transistorforum.nl/forum/index.php?id=2926</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=2926</guid>
<pubDate>Fri, 12 Mar 2010 11:33:11 +0000</pubDate>
