<title>Nederlands Transistorforum - Bedankt Maurice</title>
<title>Bedankt Maurice (reply)</title>
<content:encoded><![CDATA[[ Geen tekst ]]]></content:encoded>
<link>https://www.transistorforum.nl/forum/index.php?id=5099</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=5099</guid>
<pubDate>Tue, 30 Nov 2010 11:17:45 +0000</pubDate>
<category>Toestel of techniek</category><dc:creator>marcvandevoorde</dc:creator>
<title>IC-vervang type (reply)</title>
<content:encoded><![CDATA[<p>Meestal laatste getallen is de uitvoering vorm en materiaal behuizing.</p>
<p>Voorbeeld van het ic in een schakeling<br />
<img src="images/uploaded/201011281214484cf239a8e760a.jpg" alt="[image]" width="621" height="441" /></p>
<p>Gegevens:<br />
<a href="http://www.ic-ts-histo.de/fad/ics/zus/brieft.htm">http://www.ic-ts-histo.de/fad/ics/zus/brieft.htm</a></p>
<p>TAA621 Audio Amplifier<br />
 PNP Input at Gnd Potential</p>
<p> Pins:<br />
1 : Output<br />
2 : nc<br />
3 : Gnd<br />
4 : nc<br />
5 : Gnd<br />
6 : nc<br />
7 : Input<br />
8 : Ripple Bypass ( Siebkondensator für Eingangsstufe)<br />
9 : nc<br />
10: Feedback ( internal 15 kOhm Resistor to pin 1)<br />
11: nc<br />
12: Compensation ( z.B. 510pF nach Pin 1)<br />
13: nc<br />
14: Supply Voltage</p>
<p>Absolute Maximum Ratings:<br />
Vs = 27 V<br />
Peak Output Current: 1 A<br />
Input Voltage : -0.5 ... 27V<br />
Pd = 2.5 W until 85 grdC., derating to 0 at 125 grdC. <br />
  (Infinite heatsink)<br />
   = 1.6 W at 25grdC. without heatsink<br />
Tj = Tstg = -55 to 125 grdC.</p>
<p>Characteristics:<br />
Total Supply Current at Vs=12V: typ 5 mA, at 24V: typ 7.5 mA<br />
Open Loop Voltage Gain at Vs=12V: typ 68 dB, at 24V: typ 74 dB<br />
At Vs=12V, R Load = 8 Ohm:<br />
  Pout at Clipping: 0.9 W<br />
  Pout at THD=10% : 1.4W<br />
  Total Supply Current at 1.4W : typ 200 mA<br />
  Input Impedance = typ 250 kOhm<br />
At Vs=24V, R Load = 16 Ohm :<br />
  Pout at Clipping: 2.7 W<br />
  Pout at THD=10% : 4 W<br />
  Total Supply Current: typ 220 mA<br />
  Input Impedance = typ 110 kOhm</p>
<p>Bei einer Applikation mit 220 kOhm zwischen Eingang und Masse<br />
sind auch Werte für die Eingangsrauschspannung zu finden:<br />
 14 uV bei 12V und 18 uV bei 24V, <br />
gemessen bei einer Schaltung mit 34 dB Verstärkung und 10Hz<br />
 bis 15kHz Bandbreite.</p>
<p>Dieses IC der Firma SGS dürfte eines der ersten europäischen <br />
Lautsprecherverstärker gewesen sein. Der bekannte TBA800 hat<br />
eine ähnliche Innenschaltung, allerdings schon einen Bootstrap<br />
Anschluß und natürlich eine andere Sockelschaltung. Auch der<br />
SGS- Nachfolger im selben Gehäuse mit Blechwinkel zum direkten<br />
Anschrauben an einen Kühlkörper, der TCA 150KB hat leider <br />
andere Anschlüsse.</p>
<p>Auch heute noch können Sie den guten alten TAA621 für <br />
Lautsprecher- Verstärker mit nur wenigen Teilen einsetzen:</p>
<p>Der Eingang, Pin 7, soll über z.B. 220 kOhm mit Masse <br />
verbunden sein. In der Applikation des Datenblattes ist Pin 7<br />
direkt mit dem Schleifer des Lautstärkepotis verbunden. Davon<br />
würde ich abraten. Selbst der winzige Basisstrom des Eingangs-<br />
transistors kann Kratzgeräusche erzeugen, wenn das Poti etwas<br />
älter wird. Das Poti sollte über einen Kondensator <br />
angeschlossen werden. Der Eingang muss dann einen zusätzlichen<br />
Widerstand (220 kOhm) nach Masse erhalten.</p>
<p>Am Pin 8 ist die Versorgungsspannung für die Eingangsstufe <br />
zugänglich, um sie mit einem Elko von z.B. 47 uF gegen Masse<br />
zu sieben.</p>
<p>An Pin 10 liegt das, was bei einem Operationsverstärker <br />
invertierender Eingang genannt würde. Hier ist dieser Eingang<br />
aber relativ niederohmig, weil er einen internen <br />
Gegenkopplungswiderstand von nur 15 kOhm zum Ausgang hat. Mit<br />
einem Widerstand von 15 Ohm in Serie mit einem 100 uF Elko <br />
nach Masse würde eine 1000- fache Verstärkung für <br />
Niederfrequenz (und eine von eins für Gleichspannung) <br />
entstehen.</p>
<p>Am IC- Ausgang sind außer dem 330 uF Lautsprecher-Elko noch 2<br />
Zweige zur Unterdrückung von Schwingneigungen angeschlossen:<br />
  Ein kleiner Kondensator nach Pin 12. Er sollte bei <br />
Inbetriebnahme zunächst 1000pF sein, und zuletzt ausprobiert<br />
werden, weil er leider die obere Grenzfrequenz absenkt:  <br />
820 pF gibt ca. 8 kHz, 510 pF gibt 15 kHz.<br />
  Der andere Zweig geht über 0.1 uF (Folie) und 1 Ohm nach<br />
Masse.</p>
<p>In der Applikation ist die Betriebsspannung mit einem Elko von<br />
50 uF abgesiebt. Das erscheint mir zu wenig, weil man nicht <br />
immer ein ideales Netzteil hat. Ich nehme immer mindestens <br />
den Wert des Lautsprecher- Koppelelkos.</p>
<p>Zum Schluß noch ein Hinweis. Moderne ICs haben kleinere <br />
Klirrfaktoren, die an einer scharfen Aussteuerungsgrenze dann<br />
plötzlich stark ansteigen. Bei den alten sollte man für HIFI<br />
etwas weiter von der möglichen Maximalleistung wegbleiben.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=5076</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=5076</guid>
<pubDate>Sun, 28 Nov 2010 10:16:15 +0000</pubDate>
<content:encoded><![CDATA[<p>Dag Maurice,<br />
Bedankt voor de transistor info.<br />
Staat in uw machtig boek eveneens bijkomende info en vervangtype over het IC:<br />
TAA621AX1 ? Zie foto</p>
<p><img src="images/uploaded/201011281125194cf22e0f1c6c9.jpg" alt="[image]" width="980" height="421" /></p>
<p>Alle info is welkom.<br />
Vriendelijke groeten,<br />
Marc</p>
<link>https://www.transistorforum.nl/forum/index.php?id=5073</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=5073</guid>
<pubDate>Sun, 28 Nov 2010 09:29:03 +0000</pubDate>
<title>Transistor-vervang type (reply)</title>
<content:encoded><![CDATA[<p>In mijn machtige boek staat<br />
<strong>MJE370;</strong><br />
Si-P<br />
NF/S-L (audio-frequentie / schakelen-power transistor)<br />
30V<br />
3A<br />
25W<br />
<strong>BD190</strong> - vervanger ( zelfde pen bezetting)</p>
<p><strong>MJE520;</strong><br />
Si-N<br />
NF/S-L<br />
30V<br />
3A<br />
25W<br />
<strong>BD189</strong> - vervanger (zelfde pen bezetting)</p>
<p><br />
Pen bezetting<br />
ECB met het Tekentje als C (collector)</p>
<link>https://www.transistorforum.nl/forum/index.php?id=5067</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=5067</guid>
<pubDate>Sun, 28 Nov 2010 08:54:23 +0000</pubDate>
<title>Transistor (reply)</title>
<content:encoded><![CDATA[<p>Vergeten tekstcorrectie uit te voeren<br />
Hier is de goede versie</p>
<p><br />
Een kenmerk in de vorm van een punt hebben de transistoren niet Het is de zgn. TO-126 behuizing. Het metalen vlakje komt normaal tegen de koelplaat. Als de transistor voor je ligt, met het metalen vlakje naar onder en de pootjes naar je toe, is de volgorde E,C,B.<br />
Soundman2</p>
<link>https://www.transistorforum.nl/forum/index.php?id=5054</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=5054</guid>
<pubDate>Fri, 26 Nov 2010 20:23:30 +0000</pubDate>
<content:encoded><![CDATA[<p>Huub, Armand en Henk,</p>
<p>Bedankt voor de uitleg.</p>
<p>Groeten,<br />
Marc</p>
<link>https://www.transistorforum.nl/forum/index.php?id=5052</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=5052</guid>
<pubDate>Fri, 26 Nov 2010 20:14:47 +0000</pubDate>
<content:encoded><![CDATA[<p>Een kenmerk in de vorm van een punt hebben de transistoren niet Het iz de zgn TO-125 behuizing. Het metalen vlakje komt normaal tegen de koelplaat. als de transistor voor je ligt, met het metalen vlakje naar onder en de pootjes naar je toe, is de volgorde E,C,B.</p>
<link>https://www.transistorforum.nl/forum/index.php?id=5051</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=5051</guid>
<pubDate>Fri, 26 Nov 2010 19:38:22 +0000</pubDate>
<title>Transistor</title>
<content:encoded><![CDATA[<p>Dag Huub,</p>
<p>Ik vind geen referentiepunt op beide transistoren, daarom een foto van de voor en achterkant.<br />
Hopelijk kan je mij verder op wegzetten.</p>
<p>Alvast bedankt voor het meedenken</p>
<p>Marc</p>
<p><br />
<img src="images/uploaded/201011262100514cf011f3a5104.jpg" alt="[image]" width="665" height="305" /></p>
<p><img src="images/uploaded/201011262101424cf01226b337b.jpg" alt="[image]" width="656" height="291" /></p>
<link>https://www.transistorforum.nl/forum/index.php?id=5050</link>
<guid>https://www.transistorforum.nl/forum/index.php?id=5050</guid>
<pubDate>Fri, 26 Nov 2010 19:03:46 +0000</pubDate>
