Zeer zware Inkel versterkers (240 Watt) (Aangeboden)
door Leo Snoeren ⌂ @, Dongen, 28-03-2016, 10:06 (3678 dagen geleden) @ Leo Snoeren
Deze versterkers:
Met deze eigenschappen:
Features:
- PA-9324: 240W Mono 4 ohm, 70V, 100V
- Balanced XLR Input
- Link Connector On Input for Multiple Amplifier Operation
- Adjustable Input Gain from -12dB to 0dB
- Switchable High-Pass Filter
- Automatic Two-Speed Cooling Fan
- Automatic Thermal Protection
- Output Level Indicator LEDs
- AC Mains or 24VDC Powered
- Rack Mount (3RU)
Technical Info:
- Power Output (RMS) 240W
- Output Impedance or Voltage 4ohm, 70V, 100V (outputs vary depending on country)
- Front Panel LED's -40db, -10dB, Clipping and Protection Circuit Activation
- Frequency Response 70Hz - 18kHz (+1/-3dB)
- THD < 1%
- Signal-to-Noise Ratio > 95dB
- High Pass Filter -3dB@400Hz
- Input Sensitivity and Impedance 1.0V/10kÙ, Balanced XLR
- Input Level Adjustment -12dB - 0dB
- Power Source - AC 100-120VAC or 220-240VAC 50/60Hz
- Power Source - DC 24VDC
- Power Consumption 300W
- Power Switch Push-On/Push-Off with Integral Power LED
- Weight 14kg
- Dimensions (WxHxD) 482mm x 132mm x 280 mm
De versterkers werken, maar of er daadwerkelijk 240 Watt uitkomt kan ik niet testen. Ik heb er drie en vraag 45 euro per stuk, of alle drie samen voor 120 euro
