Bose freespace system controller: (Aangeboden)
door Leo Snoeren ⌂ @, Dongen, 28-03-2016, 10:08 (3678 dagen geleden) @ Leo Snoeren
Gewijzigd door Leo Snoeren, 28-03-2016, 10:12
Deze besturing voor de hierboven genoemde versterkers:
En hieronder de gegevens van de Bose freespace system controller:
A.1 Electrical specifications and controls
The FreeSpace® system controller (Model 8/32) accepts AC supply voltages from 80 to
265, 50Hz or 60Hz.
A.1.1 Balanced input terminals
Balanced inputs with gain switches, protection diodes, and RFI/EMI noise suppression.
A.1.2 Page input
Gain is switchable for either microphone or line level inputs.
Page trigger sensitivity 275V minimum
Mic input sensitivity 5mV nominal, 250mV maximum
Line input sensitivity 100mV nominal, 1V maximum
Page input impedance 3k (Mic), 200k (Line), balanced
A.1.3 Channel A and Channel B input
Balanced Channel A and Channel B inputs with gain switches.
Line input sensitivity at 300mV 200mV nominal, 300mV maximum
Line input sensitivity at 2V 1V nominal, 2V maximum
Line input impedance 2k (300mV), 7.7k (2V), balanced
A.1.4 Input common mode ripple rejection
40dB or greater
A.1.5 Opti-voice® system circuitry
The system automatically switches from music to page during paging.
A.1.6 Automatic gain control with LED indication
Adjusts paging volume. LED flickers at optimum volume.
A.1.7 Outputs
All balanced outputs with protection diodes, and RFI/EMI noise suppression.
Line output level 6V RMS maximum
Line output frequency response 40Hz 20kHz flat
Line output impedance 600, balanced
Line output paging Channels A and B paging
individually switchable
Model 25, Model 32, or Bose® 102 output level 6V RMS maximum
Model 25, Model 32, or Bose 102 output impedance 600, balanced
Model 25, Model 32, or Bose 102 frequency responseFlat power response with Model
25 or Model 32 loudspeakers
Model 25, Model 32, or Bose 102 paging Channel A On
Channel B Switch selectable
Model 8 output level 6V RMS maximum
Model 8 output impedance 600, balanced
Model 8 frequency response Flat power response with Model
8 loudspeakers
Model 8 paging Channel A On
A.1.8 Power requirements
Determined by power cord supplied 100V, 120V, 220-240V ~ 50/60Hz
A.1.9 Power consumption
7 Watts
A.2 Mechanical specifications
Dimensions: 1 5/8" (H) x 19" (W) x 10" (D)
(4.13 cm (H) x 48.26 cm (W) x 25.4 cm (D))
Weight: 5.5 lb (2.5 kg
25 euro
