Een Philips 953 stereo combinatie ontvangen per post. (Toestel of techniek)
door Maarten Bakker ⌂ @, Haarlem/Delft, 02-04-2025, 03:04 (393 dagen geleden) @ Maurice
Gewijzigd door Maarten Bakker, 02-04-2025, 03:11
Maybe Kabuto can post a picture of the type label of his unit to confirm the production date. The code on the transformer will be useful as well.
By the way, the code numbers on the PCB might suggest an older version instead of a newer version, so I'm curious.
@maurice: your transformer is most likely the >PL08 version, code number 3367x in your case manufactured in januari 1977. I had a 22RH953/00 in for repair version PL11 date 617 with transformer 33672 manufactured in march 1976.
