Tuner Akai AT-A102 (Algemeen)
door edison @, Aveiro - Portugal, 16-02-2026, 17:16 (62 dagen geleden) @ edison
Hello everyone.
I repaired my tuner which had a broken zener diode in the power supply.
It worked very well until now, but another problem has appeared:
The output level is very low, and it's almost inaudible.
I tested the amplifier and it's okay.
I checked the power supply and it's fine.
My suspicion falls on the output integrated circuit, UPC 1235C, but I would like to have some more certainty and for that I would like to know what voltages are present at its terminals.
In the diagram I have, I can't see these voltages clearly.
My question is:
Does anyone have the original schematic, where these values ​​are perfectly visible?
Can you tell me what the voltages are at each pin?
Thank you.
Carlos
From PORTUGAL, with regards
Carlos
