Tuner Akai AT-A102 (Algemeen)
door edison @, Aveiro - Portugal, 16-02-2026, 23:59 (62 dagen geleden) @ Goldline
Yo Carlos, check your mute circuut, see the output schematic :
(Test by remove the diode)
Hi Cees.
Thanks for the reply, but the problem wasn't in the mute circuit.
Let me explain:
After disconnecting the diode, I tested the tuner on the workbench, and it was working. I reconnected the diode, and it was working fine.
I put the tuner back in the music center, and it started malfunctioning again. (The problem was there.)
I checked everything and discovered that the antenna cable was broken near the connector.
This problem must have happened when I moved the music center during cleaning...
Best regards,
Carlos
From PORTUGAL, with regards
Carlos
