Hoe werkt deze versterker stroombron berekening ? (Toestel of techniek)
door beyopa3532 @, 18-05-2026, 08:07 (102 dagen geleden) @ Onno-I
Current source calculations in amplifiers usually depend on Ohm’s law and the transistor or circuit design being used. The resistor values help set the current flow, while voltage differences determine how much current is delivered to the amplifier stage. Once you understand the relationship between voltage, resistance, and current, the calculations become much easier to follow.
