Bouw mijn eigen Testbeeld generator (Deel 2) (Toestel of techniek)
door Sickdear ⌂ @, Nakhon Ratchasima, Thailand, 12-05-2024, 21:08 (712 dagen geleden) @ KarelWagema
Wat ik al weet is dat de PM5644 een extra PM8546 heeft (logogenerator). Wat je kunt doen is het voorpaneel verwijderen en op de knop aan de laatste kant drukken om te beginnen met toevoegen, bewerken en/of dingen tekst, datum en tijd bewerken.
PM8546 was as logo generator in PM5644 which was begun as Remove the front panel. to edit, added or remove in text, clock-date and date which PM8546 logo generator also has text editor which You must have knowledge in coding or programming EPROMS. The former are hard to find, but if you really want them, you have to try posting the code file of inaxeon (Matt's TV Barn) on GitHub, file name OpenPM8546. You can do it, but you have to be careful. too
https://github.com/inaxeon/PTV_Preservation/tree/main/PM5644/PM8546/OpenPM8546
