Technics cassettedeck RS-BX828 aandrukrollen (Gezocht)
door Goldline @, Oranjedorp, 07-01-2020, 17:00 (2457 dagen geleden) @ Bert V.
Hier het patent US3583618A Bert :
Abstract
Improved magnetic recording apparatus of the dual capstan type is provided, and particularly an improved magnetic tape transport mechanism has been devised for use in such apparatus, and which includes a reversible drive motor and a belt-coupling system between the motor and the two capstans to cause the lead capstan to be rotated at a slightly higher speed than the other capstan, regardless of the direction of movement of the tape, so as to maintain a certain minimum tape tension across the transducer heads of the recording apparatus at all times.
